How to set the property nodes to the XY graph with two Y axes?
I have built up a XY graph with two Y axes and want to manually adjust the Range of them during the test. But there are property nodes for only one Y axis (actually the second one) in the property list. Could someone please help me? I am using LabVIEW 2010. Many thanks!
(3,093 Views)
Problem solved. By using the node "active Y Scale" can one switch property nodes for each Y axis.
(3,085 Views)
