10-13-2011 02:42 AM
I am trying to initialise zoom parameters of a fft trace from labview on a Lecroy WaveRunner 6050A.I found how to set the fft parameters with the Remote Control Manual for LeCroy scopes:( http://cdn.lecroy.com/files/manuals/wm-rcm-e_rev_d.pdf ) but I didn't find how to set the parameters of the zoom menu.
I also tried to find the command using the Lecroy automation command. ( http://cdn.lecroy.com/files/manuals/automation_command_ref_manual_wr.pdf ). but I think there is a problem with the parameters of the commands that I send to the scope.
I just need to set the horizontal and vertical centers and scales.
If anyone can help,
thanks.
Solved! Go to Solution.
10-14-2011 11:58 AM
I am using F1 as my FFT trace here.
The commands to change the scales are:
Vertical Center: VBS 'app.Math.F1.Zoom.VerCenter = XXXX'
Vertical Scale/div: VBS 'app.Math.F1.Zoom.VerScale = XXXX'
Horizontal Center: VBS 'app.Math.F1.Zoom.HorCenter = XXXX'
Horzontal Scale/div: VBS 'app.Math.F1.Zoom.HorScale = XXXX'
I would also like to point you to an application on the scope that will help.
If you go to the file menu and select Minimize, to get to the desktop, there is a shortcut to an application called "XStream Browser"
The browser is an interactive application that will present all of the automation methods and properties that are available on the scope. It acually connects to the scope application so you can use it to test different items to see what they do on the scope. It is pretty intuitive and I use it exclusively. (this is where I went to get the above commands for you).
Here is a link to chapter 1 of the automation manual: http://cdn.lecroy.com/files/manuals/04_xstreamautomation_ch1.pdf
Page 1-5 Has a quick introduction to the browser and its use.
I hope this gets you up and running.
Leonard Brown
LeCroy Applications Engineer
1-800-5LeCroy
10-17-2011 10:17 AM
Thanks for your help and your advice, everything i need works now^^.
