09-26-2005 03:14 PM
09-26-2005 03:34 PM
Actually, I don't even know the model of the DAQ board, I would like to know if it would work, if not, which daq board should I purchase knowing that I am looking for the cheapest one.
03:34 PM
- last edited on
06-16-2025
02:55 PM
by
Content Cleaner
Afaik, the Keithley instruments are controlled by GPIB (IEEE-488) so you would also need a GPIB controller. What kind of NI DAQ board do you have? If it's really an NI GPIB board (i.e. PCI-GPIB), then you will first install the device drivers. If you need a new copy or what to upgrade, you can let the latest here. Make sure you install both NI-488 and NI-VISA. NI-488 is a lower level driver that does the basic GPIB bus communication. NI-VISA is an API that allows you to use a common programming interface to GPIB, Serial, USB, and Ethernet instruments. Most instrument drivers and application programs use VISA. There are instructions with the GPIB that tell you how to verify the board and drivers have been installed correctly. You set each instrument to a different GPIB address and then you test communication to each instrument. There are instrument drivers for each instrument that you can find by going to the Instrument Driver Network.
09-26-2005 04:45 PM
09-26-2005
05:00 PM
- last edited on
06-16-2025
02:55 PM
by
Content Cleaner
09-26-2005 05:58 PM
09-27-2005 08:50 AM
09-30-2005 04:24 PM
09-30-2005 04:41 PM
09-30-2005 04:47 PM
