How to set up a default printer in LabVIEW
When I click on "Print Window" all I get is an error message telling me I need to "install and select a default printer" but LabVIEW does not give me an option anywhere to select a printer. I am using LabVIEW with a SRS QCM200.
Please help
Thank you
(3,735 Views)
Do you actually have printers installed on your computer? That message is basically telling you that there are no printers connected via the operating system. LabVIEW simply uses whatever printers are installed on the computer.
(3,727 Views)
Yes, I have a default printer and a few others also.
(3,687 Views)
Can you please share your source code. So i can help you....
Thanks and Regards
Himanshu Goyal | LabVIEW Engineer- Power System Automation
Values that steer us ahead: Passion | Innovation | Ambition | Diligence | Teamwork
It Only gets BETTER!!!
(3,674 Views)
