How to set up a menu with cyrillic characters
Hello.
I need to create my application with switchable languages. One of them is Russian. That means cyrillic characters. At the moment I am facing a problem to display the menu bar correctly.
So far I have done the following:
I changed the system setting of windows 7 to display cyrillic fonts. I added the russian keyboard layout. I added the line "UseUnicode=True" in the labview.ini.
I  created string constants in the block diagram with the russian word for a menu item in a russian font type (Mac C Times) and added the line "systemFont="Mac C Times" 12" in the labview.ini.
All I get is the result shown in the attached screenshot.
Does anybody has an idea or a hint for me what to do?
regards
Marcus
(4,345 Views)
Hi, Wowawo
I never use this method before, but I have another solution for you.
property node -> RT menu path.
I use Boolean to control the RT menu path.
I have rar file want to give you, but in this websit cannot upload.
I upload at mega, you can download it at the following link.
https://mega.co.nz/#!5Jk2SYyK!z5oyFVLrxjp5Sp9UH4H73DyTkaP0qyYEOIbCujP0KrE
Hope it is helpful for you.
Patrick
Certified LabVIEW Developer
(4,316 Views)
Sorry,I misunderstand your resquests Smiley Indifferent
But you can try this solution it work or not.
(4,307 Views)
I trust you've already seen this: https://decibel.ni.com/content/docs/DOC-10153
It's about the most useful unicode help I've found for LabVIEW.  It's not really unicode friendly.
(4,302 Views)
hello dear? Have you solved the menu with cyrillic characters?
(2,345 Views)
