How to set up stops in Labview
Hello!
I need to code a program in labview to control the up and down movement of the platform of a 3D printer (with a stepper motor). At the end of the stroke there are stops which send 5V when they are activated. I managed to create a programme which, when it receives 5V, changes the direction of rotation of the motor. However, when the voltage drops below 5V, the motor returns to its original direction of rotation. Concretely, I would like the program to keep the n-1 direction and not the default one. I've tried to make a shift register but without success.
Thanks in advance for any help
(1,791 Views)
Hi Korralegend,
You should change direction based on rising edges in your end switches - and not based on the current state of the switch…
It seems you made an error in your program.
As you didn't attach the VI you need to debug on your own!
(1,772 Views)
You probably did something wrong.
Post what you have...
That crossed, once is enough.
(1,770 Views)
Hello, thanks for your answer. So i need to change my analogic input by a digital input? Sorry it's my first message on this forum. I attached to this message my VI but it's an FPGA layer so don't know if it will help.
(1,767 Views)
Hi Korralegend,
as I wrote before you need to check for rising edges:
Right now you only follow the current state of your switch signal…
You still can use the AI signal as you get a boolean value after the comparison.
(1,752 Views)
okay thanks, I will try!
(1,713 Views)
