How to set up the options file in FlexLM for LabView and TestStand
I'm getting the "Permission required to checkout license from "slic8.got.vtc.volvo.se".-error message when trying to start LabView 7.1.
Do I have to set up an options-file in my FlexLM license server? If yes, is it the INCREMENT-lines or the PACKAGE-lines or both that should be on the INCLUDE line?
Volvo InformationTechnology
Patric Kennerud
Systems Analyst
40508 Gothenburg
Sweden
(3,018 Views)
Hi Patric,
I am having the (almost) same problem here. I am using Labview 8.0 and a license server (NIVLM 2.0). Did you manage to find a solution? I noticed that noboy else replied to your question. If so, would you like to share the answer with us? thanx in advance
Ruud Habets
(2,961 Views)
