How to setting graph plot name in continuous measurement and logging sample project
I used  continuous measurement and logging project for my project, and i want to setting graph plot name by user. i write block diagram in below picture but it don't work. please help me.
(3,035 Views)
Some more details about your project may help us answer your question. Are you trying to add labels to multiple plots on a single chart or simply add labels to the plot legend?
Using property nodes is a good idea, but right now your code is changing the plot name for every plot each time the chart is updated--this is likely redundant. What sort of behavior are you observing with your code right now?
We may be able to offer more specific advice if you can provide a smaller section of code which demonstrates your question.
Andy C.
(2,963 Views)
