How to show a 8x8 stack plots?
I am measuring data from 64 channels and want to shown them in a 8x8 layout (attached picture shows part of the layout).
The waveform chart has "stack plots" but it only has one column.
How can I arrange the position of the stack plots?
Thanks!
(2,894 Views)
Hi flyingo,
by placing 8by8 graphs on your VI frontpanel?
(2,877 Views)
Thanks for the reply.
But linking data to 8x8 graphs is a tedious task and it is not easy to modify all graph's property some time later.
8x8 stack plot in one graph is easier to operate and modify, but how?
(2,866 Views)
Hi flyingo,
the point is: you cannot get a 8by8 stacked plot from LabVIEW! (Maybe you want to post this as an idea?)
You can:
- use 8by8 single graphs (with a lot of wiring)
- use 8 graphs showing 8 stacked plots each (with less wiring)
(2,864 Views)
Hi,GerdW
Thanks.
Then 8 graphs with 8 rows each seems an acceptable solution.
Flyingo
(2,862 Views)
