How to show active frame in flat sequence?
@EdHarris wrote:
but its working now
Famous last words 😁.
After the next (unexpected) 5-20 changes, you'd wish you refactored to something that works for you, the programmer.
Of course YMMV, but that is statistically and historically how it turns out.
Message 11 of 12
(320 Views)
@EdHarris wrote:
Hi GerdW,  Altenbach and Yamaeda,
The pause button doesnt always highlight the whole frame unfortunately, and in this case I prefer to look at the front panel, I used variables to turn on and off some LEDs as seen in multiple youtube but  its not elegant or very scalable I admit. This allows me to monitor the progress and interaction of the sequence along with a second similar one running on another machine. If I had time I would try to build a state machine but its working now and as it is meant to run again and again for months I am not sure a state machine is any better, thanks you helped me through. Incidentally, Altenbach the program includes a modified version of your NTP parse which allows me to access all send and receive timestamps. Thanks again.
when I do use a sequence structure, I place a string control in the first frame and update this control from frame to frame via a constant + write_local-variable to update the string control.
Message 12 of 12
(296 Views)
