How to show full function palate
Hey everyone, I'm sure this is a stupid simple question, but I can't seem to track it down.
When I use the function palate, it shows an abbreivated view, Express, Favorites, User Libraries, and then a down arrow to show the rest of the palate.
How can I set it so it always opens the full palate (as if you had hit the down arrow)?
(3,277 Views)
Accepted by topic author MrSteve
(If you get the palette via right-click, you need to tack it down to see the "view" button. )
Press "view" in the upper right corner, select "Change visible categories", then press "select all". All done. 🙂
(3,271 Views)
Ah, I know it was something simple!
Thank you so much, you wouldn't believe how much that one extra click was starting to annoy me.  Smiley Happy
(3,267 Views)
