How to show numeric values (labels) on the graph
I have been searching for quite a time but cudnt find a solution. I have shown an array on the graph. Now I want to show the numeric values of the
array points on the graph so that I dont have to always use a curser to know the XY co-ordinates while moving across the graph. How can I do that?
While searching on the forum I found , it can be done with waveform chart. Can we do it with graph as well? In Microsoft excel, option is there for this.
Thanx.
Vipin
Message 1 of 11
(9,978 Views)
You can do that with the XY graph also but not the same method. Since XY graph is an array of cluster you can pass that into a for loop (or index a single element) and display the value near the graph. If you are OK to use the Chart then you can directly use the Digital dispaly option,
Good luck
Message 2 of 11
(9,974 Views)
@ P Anand
Thanks a lot for the response.
" You can do that with the XY graph also but not the same method. Since XY graph is an array of cluster you can pass that into a for loop (or index a single element) and display the value near the graph. "
Thats what, I dont know how to show it on graph. Like using digital display option for chart, how can I show values on graph. Please suggest.
Vipin
Message 3 of 11
(9,969 Views)
Did you try doing the things what I showed you in the Image?. If you need a better solution attach your vi where you want to display the digital data. Check the vi for an example.
Message 4 of 11
(9,967 Views)
I've not tried this to check feasibility, but could you use annotations to identify each point and generate a string representation of the point coordinates?
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 5 of 11
(9,959 Views)
@P Anand
I uderstood sir,
Please have a look on attached image (front panel of my VI). I have edited it in paint. I want something like this. I want X-axis values shown on the graph.
As shown in the image, Numerical values of blue colour graph (i.e. peak position of the yellow graph ) is directly shown over it. Please let me know if I am still not clear.
Thanx.
Vipin
Message 6 of 11
(9,955 Views)
@ Thronic
Thanx for the insight. Smiley Happy It seems to make sense. I will try it. In case I am not able to do, could you please give it a try. ?
Vipin
Message 7 of 11
(9,947 Views)
A quick knock-up might look like this:
You can disable the arrows and point symbols if you don't need them, just inspect my block diagram to see how.
Message 8 of 11
(9,940 Views)
@Thronic
Thanks a lot but I am not able to open the VI as I have Labview 8.6 with me. The file you uploded is of later version. Can you please upload 8.6 compatible file. Also, can we feed data to the annotation so if, as mentioned in the PIC uploaded by you, peak position changes annotation position also changes on its own.
Vipin
Message 9 of 11
(9,923 Views)
Accepted by topic author Vipin_Saklani
Here you go, LV 8.6 (untested)
Message 10 of 11
(9,916 Views)
