How to show the ellipse found in the IMAQ shape detect to the image
I have come out with the VI which had detected the ellipses. The ellipse result shown in the last part just only shows the number of matches and also the ellipses information. The problem is I wanted the ellipse found shown in the image to show where is the ellipse that detected in the LABVIEW but not only showing me the number of ellipse detected. Because I wanted to know the ellipse detected in the image provided that other shape is also in the image. Sorry for the bad English maybe I don't know use English to state my question correctly. Thank you for the helping I stuck in the last part to complete my task.
PS: I have attach my VI and image that I used in below. The minimum score set it to 990 and it will show the result of 3 numbers of matches. Anyone know how to locate the 3 ellipse in the image? Thank you for the help
(3,294 Views)
Hello John,
Have a look at the attached vi which is a modification of what you uploaded.
Its NOT by any means near the perfect solution but it works.
Hopefully someone will sort out fitting the ellipse on the rotated shaped. I will surely love to learn from that also.
Regards.
Daudo
(3,210 Views)
Uploaded the wrong vi in the previous.
This should have been the one uploaded.
Sorry.
(3,202 Views)
