How to simplified the SUBVI terminal?
Hellow!
Any one can tell me how to make the SUBVI teminal as less as possible,because there's so many teminal in my SUBVI,it is not easy to connect all the teminal one by one to my main program. Thanks!
(2,386 Views)
First thing might be to look at the sub-vi a see if it may be too complex, too many functions be performed that might be made into other sub-vi's. If you must have all the signals going in and out you may want to create clusters, bundle the signals before sending them into the sub-vi, unbundle in the sub-vi. If you do this, it is a really good idea to make the cluster a type def, then if you have to change it (add or subtract one of the a "signals"), changing the type def will make the change everywhere you used the control.
P.M.
I'd better get off, we are having a bad T'storm, and the lights just flickered, (glad I'm on a UPS!)
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(2,384 Views)
