How to simulate DAQ hardware?
Hallo,
I have not DAQ hardware on my computer. Is there a software to simulate this hardware? I want to test Analog I/O VI program. Can I use SoundCard for the purpose or Is there VIs that work with SoundCard? (my computer have SoundCard).
Gena
(3,312 Views)
There are VIs that return various waveform shapes and noise if that is
what you want. You can also make a subVI that advanced through a file
with each call and returns a previously recorded or modeled dataset.
And In the right middle of the diagram palette there is a graphics and
sound palette that will allow both reading and writing to the sound card.
Greg McKaskle
(3,312 Views)
greg,
can you be a little bit more specific when you said
"And In the right middle of the diagram palette there is a graphics and sound palette that will allow both reading and writing to the sound card."
i've gone thru almost all of the function palettes and can't find that graphic and sound palette. it's in the control palette?
thanks
ran
(3,312 Views)
Attached is a screen shot of my functions palette that shows where the graphics and sound palette is. One thing to note, is these VIs are not in the base package of LabVIEW. You need to have Full or Professional in order to have these additional VIs.
(3,312 Views)
