How to simulate data to display on Waveform Chart/ Waveform Graph in real time ?
Hello Everybody.
My name's Chompool. I'm new in here.
I'm interested in LabVIEW Programming (Ver.2010).
I try to simulate input to display on Waveform Chart/ Waveform Graph in real time
X-Axis:       Time
Y-Axis:        Input
I try to simulate data as detailed below.
X    0     1     2     3     4     5     6     7     8     9     10     [Time (seconds)]
Y    1     1     1     2     2     2     3     3     3     3      3      [Input]
at the time 0 - 2 seconds, input = 1
at the time 3 - 5 seconds, input = 2
at the time 6 - 10 seconds, input = 3
I try to use paint program from Windows OS for draft a graph.
(as attached file)
Please advice me, how to use the funection on LabVIEW.
The data is displayed in real time.
For Example.
at 0 seconds     Value on Y-Axis displayed 1
at 1 seconds     Value on Y-Axis displayed 1
at 2 seconds     Value on Y-Axis displayed 1
at 3 seconds     Value on Y-Axis displayed 3
It will gradually show the information in real time.
As I try to simulate, All data is simultaneously displayed on the waveform. Which I did not want this.
I am a rookie.
Thank you
Message 1 of 9
(5,119 Views)
Hi Choompoo,
LabVIEW comes with a huge library of example VIs. There are also example on how to use charts and graphs…
Some ideas:
Message 2 of 9
(5,107 Views)
Thank you GerdW.
I will try again and report to you later.
What's a function at left side of XY-Graph.
Message 3 of 9
(5,102 Views)
Index&Bundle Cluster Array
Message 4 of 9
(5,098 Views)
I try.
I would like the results as shown in XY Graph and Wave Form Graph.
But All data show in graph at the same time.
If I need ro collect data step by step in real time.
at 0 seconds             Value on Y-Axis display      1
at 1 seconds later    Value on Y-Axis display      1
at 2 seconds later    Value on Y-Axis display      1
at 3 seconds later    Value on Y-Axis display      2
What should I do ?
I think maybe use dalay value.
Message 5 of 9
(5,071 Views)
I would like the result same this VI.
But I do not to show zero value of next step.
Message 6 of 9
(5,063 Views)
Hi Choompoo,
when you need to collect data in arrays you should do so!
This is a very basic LabVIEW exercise so I recommend to take the free online courses offered by NI on their website.
Learn about using shift registers…
Message 7 of 9
(5,038 Views)
Gerd's example with the chart inside the for loop should do exactly what you want of you simply add a wait (ms) or Time Delay inside the loop.
Message 8 of 9
(5,029 Views)
Thank you GerdW & Dennis_Knutson
I can do it.
Message 9 of 9
(5,019 Views)
