How to simulate two sine funcitons
Dear all,
first, I am trying to create (simulate) sine function in time. For example, when I would start a VI, the function starts to change (sine wave). After that I would need a second function, that would be dependent on the first one, but with a certain lag. For example, when first function increases, the second one would follow the first one but with the certain time lag in between.
Any ideas? I tried using while loop and a sine function, but couldn get anywhere 😕
The VI is attached.
Thanks in advance.
z
Message 1 of 11
(6,079 Views)
Hi zigolin,
"time lag" usually means "phase shift"…
Have you tried to calculate your 2nd sine wave with a phase shift?
In general it helps to write down the math ("formulas") before starting to code them. Can you supply the needed formulas?
Message 2 of 11
(6,064 Views)
Yes, sure.
f(x) = A*sin(2*pi*freq*t)
g(x) = A*sin(2*pi*freq*t + phi)
where phi is a phase shift, freq is frequency and t is time. In attached VI, I created a cosine wave, but I have a problem running it repeatedly, so I would get more periods on graph.
Thanks.
Z
Message 3 of 11
(6,034 Views)
Hi zigolin,
so all you need is to implement the "+phi" part in the loop!
Where exactly do you have problems with?
Message 4 of 11
(6,032 Views)
Not just that. Actually the VI now calculates only on period, I would like the it would contniouslly calculate this periods (from 0-25) until I stopped it. The I would add another wave that will be phase shifted. I guess that I have wrongly determined while loop to do so?
Thanks Z
Message 5 of 11
(6,028 Views)
Hi zigolin,
while I usually suggest to get rid of ExpressVIs this time they are really helpful to implement your problem:
(Both ExpressVIs are set to the same settings.)
Edit: I just learned you cannot change the phase while the VI is running, by default the ExpressVI does not use an updated phase value. You need to send a TRUE to "Reset signal" too…
Message 6 of 11
(6,024 Views)
Thanks for that! Any ideas how can I get this done using my VI?
Message 7 of 11
(6,020 Views)
Hi zigolin,
Either implement your formulas in your VI or take my suggestion! 😄
Message 8 of 11
(6,017 Views)
Perhaps I have asked question wrong: I would need to make it that way, that when I start the VI, the sine wave would start draw on front panel (graph), so for example, after 5 second, there would be 3 periods on the graph I if I don't press stop, it would still draw new periods.
Message 9 of 11
(6,012 Views)
Hi zigolin,
you you want to create a larger plot from those generated sinewaves?
Either use a chart (with it's own history buffer) or build your own larger waveform using AppendWaveforms!
Message 10 of 11
(6,009 Views)
