How to slow down indicator update
I have a VI mainly composed of a while loop acquiring data from an analogic input at 100 Hz. However, if I connect the indicator directly to the read signal, the indicator is updated at the same frequency (100Hz). How can I keep acquiring the signal at 100Hz but only update the indicator at 10Hz ?
Thank you,
Philippe
(3,336 Views)
Place the indicator in a case structure. Now use "quotient&remainder and divide the iteration counter of the loop by e.g. 10. WIre the remainder to the case selector terminal,  leave the default case empty and make the case with the terminal in it "case 0".
Every 10 iterations, the indicator will update. Modify as needed.
(3,333 Views)
Thank you! I didn't think this was so simple... 🙂
(3,305 Views)
