How to snychronize to AWG33250A
I have doneload the driver from NI web. But, I can not get the same output when I manually set these 33250A (all the connections are done by the directions in the manual book for synchrnization). Can someone share your experiment about synchronizing two 33250A? Thanks a lot.
(2,560 Views)
You should ask for help from agilent local support.
(2,536 Views)
