How to solve memory full issue while reading tdms file
Thank You Yamaeda for the suggestion, Actually I want to create just one tdms file & alter it continuously on reaching required file size - Data inserted in the first loop instance is deleted & latest loop instance data is appended, just like a pipe or stack.
Message 11 of 13
(487 Views)
Well, the only way to do that is to read all to memory, manipulate the data and write it all out. Depending how big the file is it might be manageable. Or you'll have to preallocate the file and overwrite data incl. a timestamp so you can read it out and sort it later.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 13
(485 Views)
Can i solve this using DVR ?
Message 13 of 13
(435 Views)
