How to solve this Error code/ string code: -1073807343/ ASRL1::INSTR
Help...Anyone can offer their help is really apprieciated. Thank you.
I'm trying out this program (LabView) to run the temperature Chamber and there's this Error code : -1073807343 and this ASRL1::INSTR
What does this mean ??Is there anyway, I can rectify this problem.
Thank you
Nicholas
(3,049 Views)
Hi
Go to LV-help and search for "visa error codes". There you'll find a list with all error codes. This is what it says about your error:
Insufficient location information or the device or resource is not present in the system.
Check if you provided all the necessary information about your device and if it is correct.
Using LV8.0
Don't be afraid to rate a good answer... 😉
(3,043 Views)
Becktho is correct, usually there isn't enough information for that Serial connection. Another thing that can cause this problem is a bad VISA resource name. ASRL1::INSTR may not be correct. You may want to change that control to show COM1. This can also correct this problem sometimes.
Best of Luck. If you're still having problems, please let us know. We'll be happy to help out more!
-Matt S.
LabVIEW Integration Engineer with experience in LabVIEW Real-Time, LabVIEW FPGA, DAQ, Machine Vision, as well as C/C++. CLAD, working on CLD and CLA.
(3,023 Views)
