How to sort the maxvalue from realtime chart
How to sort the max value of the Realtime sort, because the array is dynamical.
My Idea is in the attach.
(1,579 Views)
There is a function Array Max/min
(1,555 Views)
I know but the problem is the data is realtime
(1,553 Views)
I would start with the learning resources listed at the top of the forum, because your code makes very little sense.
  • Your while loop operates on the very same data billions of time a second forever, and since the indicator is after the loop, it will never show anything. It would show after you stop the loop, but since you wired a FALSE constant, all you can do is abort the VI and the indicator will never receive any data.
  • If you want to operate on new data, both the waveform acquisition and the indicator needs to be inside the loop. Dataflow! Also place a reasonable wait to define the loop rate.
  • If you just want the max value, you don't need to sort, just use "array min&max".
  • The term Realtime has a very specific meaning in engineering. I doubt you are using LabVIEW RT and relevant hardware. I assume you just want to show the max whenever new data arrives.
Here's a quick simulation:
or even:
If you want to keep track of the global max, that would be easy too. (there is also a ptbypt function for same)
(1,549 Views)
(1,531 Views)
  • Do not attach a new VI with exactly the same name as an old VI attach earlier.
  • You did not listen to our advice (loop cannot be stopped, loop has no timing, etc.)
  • Your VI does two different ways tho get the max, the simpler way is sufficient. (O(N) vs O(NlogN))
  • Does it work and do what you expect it to do?
(1,502 Views)
