How to specifically control column widths in an HTML report
I am generating an HTML report that consists of several detail tables followed by a summary table at the end. Each detail table is generated within a for loop. The summary table is generated separately at the end. The detail tables all have the same column width and same number of columns. However, I cannot get the summary table to have the same column width even though it has the same number of columns and the same column width setting.
(3,415 Views)
Hello TLE,
The problem with HTML Tables is that they adapt to the width of the text if you dont specify a value for the width of each column.
In the detail table your string was "Cycle Number" for the first column and "Date - Time" for the second Column. Further the data for "Date - Time" column was quite long so all the detail tables were looking alike. But when you changed the data and titles for the summary table, everything changed.
Try adding "& nbsp;" (non-breaking space) after the text or specify the column width to make sure the column size is correct.
I am attaching the changes HTML file for your reference.
I hope it helps,
Rajiv
(3,415 Views)
