How to specify input length requirements?
Hello, i'm creating a .vi that renames files and moves them to a specified directory.  The name is generated off of several inputs which from time to time the users enter too few or too many characters into the string control inputs.  Example: employee ID number must be 9 characters then enter only 8 or 10 on accident and it allows it to go through causing the file to be named wrong.  How can you specify that the string input must be 9 characters and if it is not pop up a message saying the string must be 9 characters.
~Thanks
(3,673 Views)
The very first function on the string palette is String Length.
(3,670 Views)
I must not understand, that will return in length the number of characters in the string.  How do I use it to limit the amount of characters entered into the string.
(3,650 Views)
You use the function to determine how many characters were entered. If it's not the correct length, you call a pop-up, just like you mentioned in the original question. There is no property to set the minimum and maximum number of characters of a string control. You have to write code to handle it and the function I mentioned is a key element of the code you write. You would simply pass the number of characters to an Equal function. This would all be handled in a basic Event structure.
(3,638 Views)
Don't forget to remove White space before doing the comparison, CR + LF count as characters, so someone typing 8chars then hitting enter could give you 9 for your comparison if you are not careful.
James
CLD; LabVIEW since 8.0, Currently have LabVIEW 2022 SP1 installed
(3,618 Views)
This program can help you out.
(3,613 Views)
