How to specify socre in Golden Template.
Hello to all.
I have an application which it compare an image with a template with Compare Golden Template VI.
My application is based on this example
It works fine.
But now I would like to implement an Score in golden template like Pattern Matching VI does.
So that user can put the Score to determinate if image pass or not.
How can I do that with Golden Template?
Thanks a lot.
(3,708 Views)
Can anybody help me?
Thanks a lot.
(3,657 Views)
Pattern Matching or Geometric Matching methods are little bit different compared to Golden Template Comparison.
-The name Matching and Comparison could be confusing here.
-Golden Template Comparison Produces the Binary image which is the subtraction of Test image with Template (Known as defects).
-One simple way i could think of is Do Particle Analysis on the Result image and based on the the particle region and/or area and set the Pass/Fail Percentage.
-Read More here: http://zone.ni.com/reference/en-XX/help/370281AD-01/nivisionconcepts/golden_concepts/
uday
(3,648 Views)
Thanks a lot for replying.
I did something like that.
I take every diferent particles between template and image.
Then an VI calculate %Area of each particle and then I set Pass/Fail Percentage.
Thanks!
(3,646 Views)
