How to specify source IP address when opening TCP connection?
Hi !
We are building a system in which a server communicates with a multi-homed Linux client with three network interfaces.  All interfaces are routable to the server, but the server only accepts connections from one of those interfaces.
We need the server to specify different local source addresses for each client but the Open_TCP_Connection vi does not provide the capability to specify the local source address.  Is there a way in LabVIEW open a TCP client connection and specify the source address?
-John
(3,970 Views)
I don't have a good picture in my head of what you're trying, but might the "TCP Create Listener Function" help?
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/functions/tcp-create-listener.html
Example: TCP Communicator - Passive.vi
(3,935 Views)
Yes, we thought about that, but wouldn't Create_Listener require the client to open the connection?  We would like to the server to initiate the connection; just wish there was a way to wire the source address to the vi.
(3,909 Views)
What you are describing would mean that your server machine is creating client to communicate with another server. Client never accept a connection. They alwasy connect to a server.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,885 Views)
