How to split a file
Hi there,
I have a file with over 700,000 lines of data in it!!!
As you can believe this is far to much for the computer to handle,
So i was planning on splitting the files into 65,000 lines so that excel can directly read it.
Each one taking the orginal fine taking a 65,000 chuck section and making it into a new file.
Can anyone please point me in the right direction???
Pete
(2,839 Views)
Try this. Incredibly simple, but I believe it should work. Both VIs can be found in the File I/O palette.
___________________
Try to take over the world!
(2,833 Views)
