How to split characters of 1D array
I'm looking for some way to split the 'characters' of a 1D string subarray. For example instead of:
1/ AAAABBBB
2/ CCCCDDDD
3/ EEEEFFFF
etc
so there would be two separate 1D arrays where before there was one:
1/ AAAA and also BBBB
2/ CCCC and also DDDD
3/ EEEE and also FFFF
etc
Message 1 of 9
(6,061 Views)
Are all your strings the same length or is there any way to know where (which index) to split the strings ?
CLAMaxime -- Kudos are a great way to say thank you
Message 2 of 9
(6,054 Views)
Accepted by topic author Sidleg
Something like this?
Do you have better requirements on where the split should happen?  I somehow doubt you just want a simple split at a constant location.
Message 3 of 9
(6,046 Views)
All the strings are 8 characters, and I need to split them into 2 x 4 characters.
Message 4 of 9
(6,042 Views)
Crossrulz guessed it right then 🙂
Message 5 of 9
(6,034 Views)
@crossrulz Yes that's it! What VI are you using for that, please?
Message 6 of 9
(6,030 Views)
Have you not come up with any solution on your own? This is a very basic thing to do. Perhaps you should also go through the free online tutorials.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 7 of 9
(6,024 Views)
@crossrulz - found it, thanks again.
Message 8 of 9
(6,015 Views)
Don't know what happened, but a reply I was responding to disappeared. Oh, well, never mind...
Mike...
LabVIEW Champion
Message 9 of 9
(5,991 Views)
