How to split data into different sheets in excel?
I've created a program that can generate report into excel. but all the data is display only in one sheet and i want to split it into different sheets. I'm using Labview 2012.Thank you in advance.
(4,632 Views)
Hi emme,
you need to write those data into seperate worksheets!
Maybe you should attach your VI for further suggestions…
The main point is: HOW did your write your data "into excel"? Which functions did you use?
(4,614 Views)
Accepted by topic author mimi345
Hi emme345,
Maybe you can try to insert a function vi called Excel Add Worksheet after the New Report vi in order to create a new Excel worksheet.
You are also able to select which worksheet you want to write to by inserting a vi called Excel Get Worksheet.
Please refer to the link below as your reference. You can download the attached vi and modify it for your application.
Write to a Sheet other than Sheet1 of an Excel Spreadsheet (Report Gen)
https://decibel.ni.com/content/docs/DOC-5468
Write Data Into New Worksheet of Existing Excel Workbook
https://decibel.ni.com/content/docs/DOC-20014
Hope this helps.
Warmest Regards,
Rebecca
Nationall Instruments
(4,569 Views)
