How to stack plots using Waveform Graph??
But I have like 19 different graphs which must be stacked with different Y-axis scales... Pls advice..
Message 11 of 13
(3,199 Views)
Let's keep your question to the original thread you started.
Message 12 of 13
(3,175 Views)
If you just wish to seperate the data streams for clarity, and you dont care too much about the vertical scale eg for simple digital data, you can simply displace one of the data streams so it displays below (or above) the other plot.
This is handy for  creating space saving graphs of a few signals, for diagnostics early on perhaps, where you dont need scales.
Using the "duplicate scale" feature can also come in handy.
You can elaborate on this, even programmatically calculate  the displacing if you need to.
Take a look at DATEx, FOTEx, HELEx & SIGEx add-in trainer boards for NI ELVIS 1,2 & 2+ and DXIQ, ESSB for NI ELVIS III and myDSP for myDAQ to learn Wireless Telecoms, Signals & Systems, Fiber Optics and Green Energy principles (www.emona-tims.com)
Message 13 of 13
(2,609 Views)
