How to start I/O server programmatically
Dear All,
I write a vi to create shared variables and Modbus TCP server with in a process programmatically.  After running this vi, In Distribution System Manager window, all the shared variable is there but modbus io server is not running!
When I right click the modbus io server node in Distribution System Manager window, select edit io server, left click on OK button to close Configure Modbus I/O Server window without any change, after unfolding modbus io server node the modbuse  io server is running!
I have use Enable Process VI to run the process. Do I have to do anything to start I/O server?
I use LaView 2011 with DSC module.
Jonathan
(2,964 Views)
Could you please post your VI here?
(2,922 Views)
