How to stop an event structure in a while loop
@X. wrote:
That or you could generate a notification from the Event Case where you detect a stop action (and of course have your processing VI monitor this notifier).
Personally, when things may take a long time and I expect the user to change his mind, I pop up a progress bar from within the "Computing VI" with a "Cancel" and "Abort" button.
"Cancel", well cancels the whole thing, While "Abort" returns the results achieved so far (if that aplies).
THis is good advice. Regardless though, The processing code will have to be organized in such a manner that it can detect the Stop event during processing. State machines offer a nice way to transition between tasks and allow the check to occur during processing (check between each state for instance).
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 21 of 26
(2,327 Views)
Responding to the progress bar inputs also requires some kind of state machine architecture. The simplest of which is when the processing involves a For or a While loop, which updates the progress bar either at each iteration or a subset thereof (the Loop is the "State Machine"). The main disadvantage of the progress bar is that it is obnoxious (even if you make it a non-floating window).
Message 22 of 26
(2,319 Views)
the solution is to include a timeout event, no matter who is empty
Message 23 of 26
(1,894 Views)
Canzaca,
Please don't revive 5 year old threads. If there's something you have a question about, feel free to post a new thread.
Message 24 of 26
(1,886 Views)
This is a long thread last active five years ago.
You probably should be significantly more specific this which post your "solution" applies. Thanks!
Message 25 of 26
(1,849 Views)
Good advice.  In this way I can press other butons while a process trigged by an the event structure is running.
Message 26 of 26
(1,609 Views)
