Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How to stop my 1553 Remote terminal application from locking up the Front Panel when the Bus Controller application is causing msgs traffic over the 1553 bus. This simulation uses WIN98SE with excalibur ISA cards.
Louise Akins
Member
04-06-2005
07:57 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
This simulation has several transmit and receive messages. The fastest message refresh rate is set to 50Hz (20 ms).
0
Kudos
Message
1
of 2
(2,703 Views)
Reply
Re: How to stop my 1553 Remote terminal application from locking up the Front Panel when the Bus Controller application is causing msgs traffic over the 1553 bus. This simulation uses WIN98SE with excalibur ISA cards.
JenK
NI Employee (retired)
04-08-2005
12:18 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Can you provide some more information about what hardware and software you are using? What is your application? Thanks!
JenK
0
Kudos
Message
2
of 2
(2,681 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
