How to store configuration data from clusters to TDMS files
It is a common use case to write measured data to a TDMS file, while the configuration information for your test is stored in a cluster (and that cluster might contain additional clusters, arrays etc). TDMS does not have native support for clusters and some other data types.
This LAVA discussion thread contains a VI library that breaks clusters of arbitrary complexity down to their basic elements and writes their contents to TDMS properties either at file, group or channel level. It also contains code that reads your data back from TDMS and recreates the original cluster type.
Please review the whole thread in order to understand what to expect and to make sure you have the latest version.
Herbert
Message 1 of 1
(2,743 Views)
