How to store values
I want to store values in Channels which were caculated as variables. I can see the answer with a MSGBox, but I am unable to store this value in a Channel. How can I store values in Channels?
Thanks!
(3,062 Views)
Please explore your question in detail or post VI to get more idea.
(3,042 Views)
I want to calculate an average value from different channels. The values to calculate the average from are at different  positions in the specific channel. I am able to get this values and to calculate the average. But then I can not store this value in a channel, because it is not from a channel, it is just in a variable.
I tried it in a different way with the statistik function but there I am not able to get a specific area for each channel.
Thanks!
v=1
Andruck1 = (((v-1)*14)+12)
Andruck2 = (((v-1)*14)+13)
'Here I calculate the area where the values for the average are located in the channel
For a = 2 To 2000
      Anfangswert = ChD(a,Andruck1)
      If Anfangswert >= 20 and ChD(a-1,Andruck1) < 20 Then
      Zeit = a
End if
For x = 0 To 200  'Here I calculate the average with the first method
      Wert1 = Wert1 + ChD(Zeit+x, Andruck1)
     'Wert2 = ChD(Kraft, Andruck2)
      Mittel1 = Wert1 / 201                                             'How can I store Mittel1 now in a channel?
      beta = Zeit + 200
      StatSel(6) = "Yes"                                                 'Here I want to caculate the average with the statistik function,
      Call StatBlockCalc("Channel","Zeit-beta","12")     but the area is not always the same, and I always get a syntax error
        What is the right syntax to write "Zeit-beta"?
(3,039 Views)
