How to sum y values for a specific x range in the waveform graph
Hello, I have a waveform graph that looks like below. Each bin is 5 ns and the total counts are the sum of y values for the whole x range. I wonder how to sum the y counts for an x range, such as 100-300 ns. My thought is to make a for loop to add the y value for every single x in the range of 100-300 (Not sure). If it is a curve, I may do the integral for x=100-300. Thank you
(3,350 Views)
Accepted by topic author beyonddd
Hi beyond,
The data should be provided in an array, so all you need is an ArraySubset function followed by SumArray…
(3,344 Views)
Got it. Thanks a lot, GerdW. I will extract the data as an array and try it.
(3,323 Views)
If it's a graph, you're providing an array as an input.  That's the data that's being represented by the graph.
Just take the subset of the array you're interested in.
(3,259 Views)
Thank you, I have figured it out.
(3,238 Views)
