How to switch between 3-4 constant image every 1 second?
I want switch 3 constant images that switch every 1 secind. is it possible?
how?
Message 1 of 12
(2,296 Views)
Make an array of images (IMAQ? Pictures? Pixmaps? doesn't really matter).
Make a while loop with a 1 sec. wait in it.
Use the iterator with a quotient & remainder to get the current image.
Show it.
Message 2 of 12
(2,291 Views)
Hi iLay,
Yes.
@ilayLab wrote:
how?
Use a PictRing and change its value each second…
Message 3 of 12
(2,289 Views)
Use a picture ring. (EDIT: that crossed, busy making the example 😁)
Or, use an animated gif...
It depends on what you really want.
Message 4 of 12
(2,288 Views)
i want that the screen change the pics every second (not a GIF)
Message 5 of 12
(2,272 Views)
also, i am new in this bussniess so i dont really know what is pic ring...
Message 6 of 12
(2,267 Views)
i will glad if you can explain what did you her??
Message 7 of 12
(2,259 Views)
You mean "what I did here"?
I made 4 images and switch between them every 1 second...
That image is a snippet, see Using VI Snippets to Store and Share Reusable Code Sections - NI. Be careful how you download the image, the image in the thread is reduced and the LV info is removed... Open it in a separate tab and save it there.
Did you do the free online courses?
Message 8 of 12
(2,249 Views)
NO, I didnt do it. I work with this software because I am taking an Automation course at my University and i got a small project to do.
I will read carefully the explanation you wrote to me and try to do it myself.  I would be happy if you explain what you did here (in terms of all the elements)
Message 9 of 12
(2,245 Views)
Message 10 of 12
(2,242 Views)
