How to switch trends on and off in a graph
Quite new to this so bear with me.  I've numerous temperature sensors I'd like to be able to display on a graphical display.  To display all of them on one graph would be a bit of a headache for the user and I don't want numerous graphical displays.  I'm after the best way to code this up so I can select the required channels by using individual boolean switches for each channel.
I'm thinking that a switch next to each channel name would be a neat solution to switch channels on and off on the graph.
Thank you
Carl
(2,491 Views)
Accepted by topic author Carl.G
LabVIEW 2013 has inbuilt Plot Visible selection in Plot Legand in Waveform Graph
(2,484 Views)
Thank you.
(2,478 Views)
