How to synchronize CRIO multi chassis
I have two NI-9076 and each populated with NI-9234 DSA ,NI 9870 RS-232(IMU&GPS) and one digital input 9401 modules.How to synchronize CRIO multi chassis with DSA&IMU&GPS Measurements modules. There has to be another method for multi-chassis synchronization for DSA modules.Any idea has this can be done? Thanks.
(2,791 Views)
Hi there,
That is certainly possible.  Please refer to the following general document regarding synchronization of Real-Time systems using NI-TimeSync: http://www.ni.com/white-paper/11566/en
As well, the following might be helpful regarding DSA modules more specifically; this uses the Simple TCP/IP Messaging (STM) library: https://www.ni.com/en/support/documentation/supplemental/21/simple-messaging-stm-communication-libra...
Best,
Ryan C.
(2,767 Views)
