How to synchronize the Acquization part and control part?
I'm still on LV 6.1 so I can't read your vi. I would be happy to take a look at it if you would repost it in 6.1 format.
Message 11 of 23
(1,331 Views)
The Sub-VIs:
- Steper_SUB.vi
- Setup_6025E.vi
are not included
=> LLB
Message 12 of 23
(1,222 Views)
Lorand, those two subvis are not very important
for the purpose, and they include some other files.
So I did not upload them.
Message 13 of 23
(1,222 Views)
John, can you get a labview 7 evaluation version? I am not a full time worker, so the resource is very limited(not easy to find a Labview 6.1). Or you can post
several samples which can demonstrate all the ways to sychronize the DAQ. This is a missing part for many of us.
Message 14 of 23
(1,219 Views)
You should be able to use the "Save to previous" feature to save your LV 7 vi to LV 6.1. Look under "Save with Options" to find this feature.
Message 15 of 23
(1,219 Views)
This is a test program. Only check one analog
input.
Message 16 of 23
(1,219 Views)
All the files here.
Message 17 of 23
(1,219 Views)
Look at the "red" commentfields in the attached VIs
comment: 2 comments
solution: 4 comments
Is this what you wanted?
Message 18 of 23
(1,219 Views)
Thanks a lot Lorand. There is one thing not clear
to me. There are 3 states in this machine. In each
state, the program will stay there about 5 seconds.
In the new solution, how to add this feature?
Message 19 of 23
(1,219 Views)
I see that Lorand has applied comments and a solution below. I expect that he pointed out that your vi is very hard to read because of the sequence structures and the fact that these are spread out over a wide area. Also, you used a lot of local variables which could be avoided in a true state machine structure.
It appears to me that you have a specific point in your program where you want to retrieve data and at another point you want to write data to port. This is easily accomplished with queues and notifiers. I can't read Lorand's solution (LV 6.1), but I expect that the solution deals with these issues appropriately.
Message 20 of 23
(1,219 Views)
