05-01-2012 07:11 AM
Hi all,
I am currently using a Zaber linear stage for towing models and a NI USB-6289 DAQ board to acquire data from sensors mounted on the model. I use a simple VI with a DAQ assistantto acquire data from the USB-6289. I installed an external LabView driver provided by Zaber and I am using one of their example VIs to send a series of commands to the linar stage to perform motions. These are two separate VIs at the moment. I have attached snapshots of the VIs.
I want to synchronize the start of the motion with the starting time of data acquisition from the DAQ board so that I can co-ordinate the signals at each timestamp with the position of the model at that time. The data acquisition from the DAQ board starts when I run the "DAQ.vi". For the linear stage, I input the parameters in the front panel and motion starts as soon as the requests are sent to the device. I have highlighted this part in the block diagram.
What is the best way I can synzhronize these two separate tasks in different VIs? Should I integrate the two VIs and then try do this? I am pretty new to LabView so it would be great if any of you can help me with this.
Thanks a lot!
05-01-2012 07:20 AM
I am attaching the vi files as well. I believe the Zaber vi will only work when the driver is installed. I am attaching the driver here as well. It can also be found in the Help menu >> Find Instrument Drivers >> Search for the keyword Zaber.
Thanks!
05-01-2012 07:21 AM
You can use many structures from the "synchronization" pallete menu. I used the notifiers in the example. Keep in mind that notifiers do not queue up, once the wait on notification function misses the notification, it wont know it happened.
05-01-2012 07:28 AM
Dear s.vignesh,
I am also controlling a linear stage and a DAQ with loadcell values continously, Here is my block diagram maybe this will helpful. It is not finished yet. I have been busy with this since 2 mounths. Trying to learn Labview by the time. They can be in the same vi. Putting them at the same while loop may be the solution to synchronize.
Kind regards.
