How to take characters to hex then the resulting hex to a text file?
Hey,
I'm trying to take say a the word alpha and convert it into hex (616C 7068 61)then write the hex values to a text file. When I use a stringol with hex display set and wite to a text file, it writes the word instead of the hex. How do I convert the text to hex text??
Thanks for your help...
(2,761 Views)
First convert the string to an unsigned byte array using String to Byte Array.  Then convert the unsigned byte array to a hex string array using Number to Hexidecimal String.  Then convert the string array to a string using Array to Spreadsheet String.  See attached:
Message Edited by tbob on 10-06-2005 06:25 PM
- tbob
Inventor of the WORM Global
(2,758 Views)
Thanks, makes perfect sense.
(2,751 Views)
