How to tell when a teststand sequence ends in labview?
Hello Community,
32-bit Teststand 2014
32-bit Labview 2015
I am using the Labview version of Teststand Simple UI and I created a simple teststand squence file to run.
Where in the Teststand Simple UI can I tell when a sequence file is finished or is there a way to tell when a sequence file has finished running in Labview?
I want to perform an event handler when a sequence ends that will trigger a value change of a control.
I understand how to create an event handler when a control changes value, but I don't know when to trigger it. I don't know how to tell when a Teststand sequence file has finished running in the Simple UI.
Any help would be greatly appreciated.
Thank you
(2,988 Views)
If you take a look at the example code I posted in your other thread
http://forums.ni.com/t5/LabVIEW/How-to-send-a-TestStand-variable-to-Labview/m-p/3262431
it shows me waiting for the TestStand sequence to end.  You also can register an event callback for a sequence ending.   Also, these questions should be in the TestStand forum since they are really questions about the TestStand API.
(2,932 Views)
