How to to continuously average dynamic voltage data
Thanks that works too!
Mike
How do I mark as solution?
Message 11 of 26
(4,881 Views)
Hello Mike,
Thanks for marking as solution 🙂
Message 12 of 26
(4,878 Views)
Hi Darin, thanks for your neat program.
I have a similar situation but imagine with no possibility to put the data source inside the while loop, in your program case imagine if the random generator is out of the while loop, do you know any method to take the average now?
Thanks in advance
Message 13 of 26
(4,669 Views)
Hi Mark
Thanks for your code, I have sligtly a different problem, do you possibly know how to average in your program "basicAverage" if the data aquision is outside the while loop?
Message 14 of 26
(4,662 Views)
@Lili_M wrote:
Hi Mark
Care to share what code you have?  I'm not sure what you are asking.
Message 15 of 26
(4,656 Views)
Here is a simplified version of my program, please consider we can only deal with the part in the "sequence structure" and we want to average the signal over time lets say it takes 10 signals and shows the average.
It would be a big help if you can help me.
PS: I can send you my code also but it wouldn't work there due to many subvis and data acquisitions.
Message 16 of 26
(4,660 Views)
this is an incomplete solution for it. if I just knew how could I show the data just when it was ready... that would be heaven..
Message 17 of 26
(4,656 Views)
You probably want to change it to use a running average.  Then after X waveforms (X being your number of waveforms to sample over), then data will always be ready.
Message 18 of 26
(4,652 Views)
very much thanks for your kind reply, but its not totaly solved yet.
by choosing "running average" it still needs a time to average the signal, and meanwhile it shows the procedure not the final averaged signal at once, so imagine for saving the data I will have issue, can you please comment on that?
thanks in advance
PS: I have attached the modified program
Message 19 of 26
(4,647 Views)
I don't have LabVIEW on this machine, but I'm guessing you could just use a case structure to only save the data when the averaging is ready/complete.
Message 20 of 26
(4,629 Views)
