How to track position of motor using LabVIEW?
I have created a VI in LabVIEW that will allow me to control a motor to turn a certain number of degrees and then the motor will provide me with feedback on its final position. For example, I ask it to turn 180 degrees and it will output 180 degrees on the screen when it reaches its destination.
Is there a way to track the motion of the motor as it turns second by second? For example, at 1 second it is at 30 degrees and 2 seconds 75 degrees, etc. I would like to display this information in a chart/graph or table.
Any help would be greatly appreciated.
(2,749 Views)
You can try use chart and wire its input with the output of the motor and put the whole in a loop.
(2,745 Views)
