How to transfer Remove Queue Element.vi from LabView 6.1 to LabView8.5?
Hello
I deal with the program written in LV6.1 and I want to use it under LB8.5, however subj. vi alwasy makea s problem. The program is stuck there... In info for subj vi it is a subvi
"Dequeue element" which was removed in LV7. What can I do to solve the problem and make the program running in LV8,5?
(2,937 Views)
Dequeue element is still present...
________________________________________________________
Use the rating system, otherwise its useless; and please don't forget to tip your waiters!
using LV 2010 SP 1, Windows 7
(2,935 Views)
It actually is there but they created an upper level set of Queue functions in LV6 which makes it confusing since the lower level function you want to use is inside the upper level VI.  I simply went into all my LV6 programs and changed all the upper level queue functions back to their primitives (they're the dull yellow colored ones).  It's a pain but it's the only solution I found.  Besides the pretty, multi-colored stoplight icons I never really understood why they added those new functions.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
(2,932 Views)
