How to transform a hexadecimal string to an array of string
I explain my problem:
I have a string which, when it is displayed in the "normal display", gives : "wuIÂ".
When this string is displayed in the "hexadecimal display", it gives: "7775 49C2"
My probem is that I need to transform this string to an array of string which would have IN THE NORMAL DISPLAY the values:
7
7
7
5
4
9
C
2
 I have tried numerous things but it never worked,
Thank you for your help
Vlanico
(3,441 Views)
- James
Using LV 2012 on Windows 7 64 bit
(3,432 Views)
Let's assume the string is a eight characters and corresponds to 4 bytes, here would be a simple solution. Modify as needed.
Of course if you want them on a single line, you would use if the output of the formatting operation and discard the rest of the code.
Message Edited by altenbach on 05-13-2009 11:51 AM
(3,418 Views)
thank you very much
(3,408 Views)
I missed my edit window but here is the vi
- James
(3,399 Views)
