How to trigger a device using DAQmx and NI 9401?
Hi all,
I am trying to trigger a device in labview by creating a sudden increase in voltage from 0 to 5. I have cDAQ9172 and NI 9401 on slot 6. I have installed DAQmx.9.7 on my computer.
I read the help and found an example in "hardware input and output/DAQmx/generating digital pulses/Gen Dig Pulse.vi", when I run it I get the following error:
Error -200220 occurred at DAQmx Create Channel (CO-Pulse Generation-Time).vi:1
I also tried to create a global virtual channel or a any task to write my own labview code but No supported devices are found in the physical channels section of data neighborhood. I really do not know what is the problem.
Thanks for your kind help.
MahEb
(3,355 Views)
Hello!
Could you make the same in the test panel from Measurement & Automation Explorer. May be you are not fully configurate your device?
Remind, that you haven't Counter Output channels on your device https://www.ni.com/en-us/shop/model/ni-9401.html, and you can't using retriggering mode with some counter.
Regards, Pavel
(3,336 Views)
MahEb,
Take a look to this example.
CarmenC.
(3,329 Views)
