How to trigger a pulsed laser
I have written a simple labview code that is supposed to trigger an ND:YAG pulsed laser. The DAQ sends some signals which can be observed on a scope but when the DAQ is connected to the external TRIG of the laser, nothing happens; it doesn't trigger the laser. I am wondering if I am doing something wrong. Any help would be appreciated.
I have attached the code. Thanks
Message 1 of 16
(2,878 Views)
What is the voltage level and pulse duration required for the LASER to trigger? Can you share the manual for the LASER driver or control interface?
Santhosh
Soliton Technologies
Message 2 of 16
(2,860 Views)
Hi ksarpong,
@ksarpong wrote:
I have written a simple labview code that is supposed to…
  • Why is the "No. of shots" control orange? It should be a blue integer value, don't you think?
  • Why is there no error handling at all? (Did you try to learn from all those DAQmx example VIs in the example finder?)
  • Why do you need to create and kill the DAQmx task in each iteration of the inner loop?
  • Right now there is NO WAY to set any timing for your "pulse" output! You start the task, output a TRUE, output a FALSE and kill the task AS FAST AS POSSIBLE in each iteration…
  • Which (DAQ) hardware do you use?
  • As asked before: which signal is required by your laser driver?
Message 3 of 16
(2,836 Views)
From the manual (pages 33-34), the laser requires 10-20 microsecond pulse width and 0 to +5VDC TTL signal. Interestingly, I was able to trigger (using the same code) when the signals are sent to the flashlamp trigger IN but not when it is sent to the Q-switch trigger IN. I want help to be able to trigger using the Q-switch trigger IN, that way the pulse-pulse shots are quite stable. I have attached the manual for the laser here and all that is needed are on pages 33-34. Thank you.
Message 4 of 16
(2,811 Views)
Interestingly, the code works when the signals are sent to the flashlamp but not when the signal is sent to the Q-switch.
Message 5 of 16
(2,802 Views)
With only a brief look at the manual, page 34 seems to suggest that you'd want to provide precisely-timed pulse signals to BOTH the Flashlamp and Q-Switch inputs for best results.
Precise timing of 2 signals will require some kind of hardware-based timing rather than your present approach of software timing.  I would personally approach this with counter tasks, but a hardware-timed digital output task might also be a viable approach.
What DAQ device(s) do you have available to use for this app?
-Kevin P
Message 6 of 16
(2,801 Views)
An image of the DAQ device I am using is attached. Thanks
Message 7 of 16
(2,784 Views)
This image is not really helpful, the model of the DAQ is the information required.
Santhosh
Message 8 of 16
(2,780 Views)
M/N: USB-6003
P/N: 15442D-01L
S/N: 1F3CF06
Thanks!
Message 9 of 16
(2,774 Views)
You got a "low-cost" DAQ, which means the features are also basic and limited.
As per your LASER manual, you need to send 150us spaced pulses to FLASHLAMP and Q-SWITCH
Santhosh
Message 10 of 16
(2,763 Views)
