How to trigger a voltage reading and freeze
I would like to trigger a voltage reading when the signal is below a threshold (I can do this with a compare block). What I don't know how to accomplish is to freeze the indicator at this voltage as well as the number of cycles at this point while continuing the process.
(2,565 Views)
Put the indicator in a case statement, with the trigger wired to the boolean input.
CC
Chilly Charly    (aka CC)
(2,552 Views)
